In this article:
- Completely uninstall Audirvāna on macOS
- Completely uninstall Audirvāna on Windows
- Completely uninstall Audirvāna on Linux
Depending on your operating system, the uninstallation of the software is different:
- Use your secondary click on the Audirvāna Studio/Audirvāna Origin icon in the Applications folder and select "Move to Bin":
Note: We do note remove your playlists & local favorites on macOS. You will need to remove your AudirvanaDatabase.sqlite file if you want to.If you can't find the Library folder from Step 1, you can choose to always show the Library folder by going to the Home folder and in the View option of Finder, select the option 'Show Library Folder':
- Use the Windows search bar and search for Studio or Origin, depending on the software you use, and select the option "Uninstall":
Note: Everything is removed automatically, including your playlists and local favorites.If you want to keep your playlists and local playlists, you have two choices:
- Do a backup of your playlist & favorites in Audirvāna (Local/Library>Local favorites, playlists, and artists pictures backup):
- Move the AudirvanaDatabase.sqlite file to a different location (Local/Library> Audirvāna Database File Path):
Note: we recommend this location: C:\Users\[your session name]\AppData\Local\Audirvana\AudirvanaCompletely uninstall Audirvāna on Linux
Removing a package on Linux is done differently based on the Linux distro you are using:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
