Selecting an output in Audirvāna
In this article:
In Audirvāna playback control
- While you are doing anything in the app, you can still see the output selected if you click on the speaker icon
at the bottom right of Audirvāna and choose the one you want to use:
In Audirvāna Audio settings
- You also have the option to view the currently used device in Audirvāna Audio settings. Click on it to see the list of audio output available to select the one you want to use:
In case you are using one of our partner's device-certified "Plāys with Audirvāna", you will be informed of the certification when you select the unit:
If you don't see your output, please ensure the device is powered on and connected to your computer.
Depending on your device connectivity, please see the different ways to connect to your device in Audirvāna.
IMPORTANT: when you are playing a track, you can't change the output due to the Exclusive access mode of Audirvāna. Since Audirvāna 'Locks' this output. Your computer will then select another available audio device and will switch to it if you use different app with sound. You need to click on the lock icon next to the speaker icon to deactivate exclusive access and be able to select again an output device in Audirvāna.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
