You can edit any playlists available in Audirvāna:
- Manual playlists to combine local and streaming tracks (Audirvāna Studio only)
- Streaming playlists (Audirvāna Studio only)
- Smart playlists are automatically updated from your local library according to your defined rules.
Editing a playlist
In this article:
Step 1: Open the playlist manager
The playlists manager is always available in the toolbar, wherever you are in Audirvāna:
Note: To keep the manager displayed in Audirvāna, click the icon at the top right of the fitler editor to pin the editor at the left or the right of your view:
Step 2: Click on the playlist you want to edit
Select your playlist in the playlist manager. It can be either a manual, streaming, folder, or smart playlist:
Step 3: Open the playlist Editor
With the playlist Editor, you can change the playlist's name, picture and add a description.
VIDEO to know more about the playlists in Audirvāna:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
