The technical mini-player is an excellent tool for checking one view of the song's modifications (format, gain, and resolution) at each processing step during the playback according to your choices of audio settings.
You can also analyze the playing track using an algorithm that reveals its resolution and checks whether it matches the audio quality featured in the file metadata. Please read this article to know more about it.
Opening the technical mini-player in Audirvāna
You have two ways to open the mini-player; you can do it by clicking on the Start Audio Scan button at the bottom of the Audio settings of Audirvāna:
The other option is to open the mini-player (Please read this article to know more about it) and then click on this icon:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
