When you sync content with Audirvāna Studio, we analyze the tracks, and thanks to the MusicBrainz database, we display missing metadata Audirvāna Studio.
This is done in the background; you can use Audirvāna Studio and exit the application whenever you want. The scan will pick up where it left off before quitting.
It helps recognize your recordings, giving you more information about your music and offering you more relevant related music in your streaming service.
Deactivating metadata retrieving
Audirvāna Studio doesn't add any metadata inside the track, but if you don't want to retrieve it, you can deactivate it in Audirvāna settings.
Note: If you deactivate the option after you synced a folder, you will need to resync this folder
In this article:
Step 1: Go into Audirvāna Local settings
Click on the settings button at the top right of Audirvāna to open the settings:
Once there, click on the Local/Library tab at the right of Audio:
Step 2: Scroll to the Metadata recovery section
Scroll down the page in the Local/Library section, and you should see the Metadata recovery right under the Add Music section.
Click on the button next to "Retrieve metadata missing in the audio file from MusicBrainz", and the metadata retrieval will be deactivated :
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
