All your favorites are under the My Music section on the left pane of Audirvāna.
Viewing my favorites in Audirvāna
You can access your Album/Artist/Track favorites in my Music section. If you are using Audirvāna Studio, you will find your Radios/Podcasts and connected streaming services under each Album/Artist/Track section.
My Music also regroups all your playlists under My Playlists, where you can find the playlists created in Audirvāna as well as streaming playlists linked to your connected streaming service (only for Audirvāna Studio).
Note: any change you do under My Music will be reflected on your streaming service and vice-versa.
The My Music section can be found on the Left pane of Audirvāna. You can then click on the section of your choice:
Each section can be sorted (please read this article to know more about it). If you are using Audirvāna Studio, you can find your streaming favorites in each of your streaming sections, which the sorting relies on the one you put under My Music:
TIDAL:
Qobuz:
Presto Music:
HighResAudio:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
