You can get help on how to use Audirvāna right when you open the software:
- The first time you open the App, you are helped with a quick set-up and then a guided tour, which allows you to familiarize yourself with the App. You can start it again in the appearance settings of Audirvāna Studio/Origin.
- Inside the App: on each of the settings of Audirvāna, you will find an
icon at the top right of any setting window, giving you more information about the setting you want to change.
We also created a set of YouTube video tutorials to explain how critical parts of the software work; you can view them on our YouTube channel:
We built a website that responds to most of your questions. You can access the knowledge base using the link below:
Note: Our community-driven forum is a great way to find answers to questions for which other users might already found answers. Feel free to share your experience, and communicate with other audiophiles of the forum.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
