To use Audirvāna on your computer, you must ensure that your system meets the following minimum requirements:
| Windows | |
| Minimum | Recommended |
Requires a 64-bit processor and operating system | Requires a 64-bit processor and operating system |
| OS: Windows 10 64-bit 1803 | OS: Windows 11 64-bit 22H2 |
Processor: Intel Celeron 3205U / AMD A10 Micro-6700T | Processor: Intel i5 10200H / AMD r3 3100 |
Memory: 4 GB RAM | Memory: 8 GB RAM |
Storage: 1 GB available space | Storage: 1 GB available space |
| Additional Notes: more storage may be required to store Audirvāna database file. | Additional Notes: more storage may be required to store Audirvāna database file. |
| macOS | |
| OS: macOS 10.13 or newer | OS: Latest macOS version |
| Processor: Intel i5 750 | Processor: M1 |
| Memory: 4GB | Memory: 8GB |
| Storage: 1GB available space | Storage: 1GB available space |
Incoming changes to macOS requirements We are doing our utmost to maintain compatibility for as long as possible, and sometimes reach the limits of older macOS versions: 10.13 (High Sierra) 10.14 (Mojave) Starting with the version 2.11.5 of Studio and 2.6.5 Origin, those above macOS versions won't receive updates from the software. Please update your macOS to macOS 11 (Big Sur) or a newer version.
| Linux | |
| OS: Debian or RPM Package | OS: Debian or RPM Package |
| Processor: Intel/AMD 64-bit or ARMv8 | Processor: Intel/AMD 64-bit or ARMv8 |
| Memory: 1GB | Memory: 2GB |
| NAS | |
| OS: Synology DSM7 or QNAP QTS 4.2.6 | OS: Latest Synology DSM or QNAP QTS |
| Memory: 2GB | Memory: 4GB |
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
