The Audirvāna window adapts to the size of your screen and sometimes you can get the left pane to only display icons.
In such case, you need to go to the extreme left side of the User Interface, so you can get the left panel back thanks to the thin slider:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
