Depending on your display size, you can Zoom in or out in Audirvāna to display fewer or more album covers.
Zoom in/out in Audirvāna
When you do have the option to change the Zoom in Audirvāna, you will see the Zoom option in the toolbar like this:
The Zoom change can be automatically seen in the app, and the zoom will be applied to every view where you see a cover:
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
