Please make sure Audirvāna is stored in this folder:
/ApplicationsTo fix this permission issue, you can use the Terminal application (you can find it in Application>Utilities) and enter the following commands:
sudo chgrp wheel /Library/PrivilegedHelperTools
sudo chmod 1755 /Library/PrivilegedHelperTools
If it’s still not working can you close Audirvāna and do the three commands below in Terminal:
sudo launchctl load -w /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plistsudo rm /Library/PrivilegedHelperTools/com.audirvana.SysOptimizerToolsudo rm /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plistOpen Audirvana and play a track to check if you still get the error.
Note: if the above step didn't worked, please create a ticket.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
