You can play thousands of radios in Audirvāna Studio, yet if one you like is missing, you can easily add it with its link.
Playing a radio with a link in Audirvāna Studio
To play the radio, click on the plus icon next to radios on the left pane of Audirvāna Studio, and a pop-up will appear to add your link and Play or Add the radio to the play queue.
If you want to keep the radio in Audirvāna Studio and find it easily, create a playlist and add the radio to it after you click on Add URL to play queue:
Note: if you can't play the radio, please create a ticket and indicate the link you tried to play.
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Feedback sent
