Why Audirvāna doesn't include my UPnP network device in the audio devices?
First, make sure that your Mac and your network drive are connected to the same local network, with no router in between.
Then check that no other UPnP applications are running on your Mac when you launch Audirvāna Studio. Only one application at a time can open the SSDP port (UDP 1900) to detect UPnP devices.
Note: for macOS Sequoia users, please make sure Audirvāna is activated in the network settings of macOS:
https://support.apple.com/guide/mac-help/control-access-to-your-local-network-on-mac-mchla4f49138/mac
Was this article helpful?
That’s Great!
Thank you for your feedback
Sorry! We couldn't be helpful
Let us know how can we improve this article!
Select at least one of the reasons
CAPTCHA verification is required.
Feedback sent
